bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
07-25-12 09:02 PM - Post#2252249
In response to MikeB
That's OK Mike, sometimes I'm not always clear.
Doc, it should have about 30 psi at idle, so I still need some ideas guys. Guess I'll have to pull the pan if the compression checks out, but not sure what good that will do. It's a new pump with probably less than 2000 miles on it, so what can go wrong just sitting? Should I run some Marvel Mystery oil in it? I'm a little affraid to run it too much with that low of pressure.
Ken
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 07 Silverado, 09 BMW 135i convert.
http://www.picturetrail.com/ken58 |
