tarps (7)
Username Post: Anyone have experience with performance sway bars?
BBChevro
BBChevro
Loc: Qld., Australia
Reg: 03-31-12
07-20-12 03:39 AM - Post#2250160
    In response to nicke
There's a lot of good advise & information to ponder in this thread.
Earlier in the thread you asked "Can you speak a little more to the negative affects of sway bars?"
Not really a negative, just some more information to ponder - The "balance of adhesion" (do you like that term? - I just made it up ) will change depending on the sizes of sway bars front & rear - the larger the front bar (in comparison to the rear one), the more understeer you'll get & likewise, as you stiffen up the rear it will create more oversteer.
Powerful, rear-drive cars (such as ours) have a natural tendency to be a bit "tail-happy", which would be why you don't generally see cars with a rear sway bar & nothing on the front - & when there's a bar at both ends the front will be larger.
Like I said, it's not a negative (I'm a fan of decent sway bars) - it's just some more points to ponder.
One more thing Nick, I'm going to do a bit of "cross threading" here (no, I didn't make that one up, just using it in a different context)...
Your other hot thread in this forum regarding a friendly grudge match - don't stiffen up your front suspension until after that event (no point in giving up any advantage).
Mark
Mark
There is light at the end of the tunnel..... hopefully, it's not a train.
Execution time: 0.083 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:18 AM
