50hotrod
Reg: 07-25-11
07-18-12 11:40 AM - Post#2249538
In response to nicke
Maddjeff Quote;
"It's not going to get the chance to wind to 6000rpms a lot, so I need to build for low-end as much as possible"...........
Don't kid yourself. You will be hitting 6000rpms on a regular basis with ease and not even realize it. Just the nature of the beast. These mouse motors love it. You will see.
You can not run self alining rockers on 461 heads without drilling out the push rod holes larger. The 461 heads use the push rod holes as guides.
You can not run self alining rockers with guide plates installed. One or the other not both.
Edited by bouncer on 07-18-12 12:01 PM. Reason for edit: No reason given.
