tarps (7)
Username Post: Dart Iron Eagle Heads
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-13-12 02:25 PM - Post#2247876
    In response to pittbull
I used a pair of 180s 9-10 years ago on a 383. Didn't have anything to compare them to, but they were well made, better in some respects than my newer Brodix IK180 heads.
I had to use longer than stock head bolts for the lower outside row because the casting there was thicker than stock. You will need to use bolts that allow at least 6 turns, and preferably 8. I've found this to be true for most aftermarket heads.
What size engine? 200cc runners are typically for 383s and larger, while a 49cc chamber would seem better suited to a very short stroke engine.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Execution time: 0.115 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:56 PM
