Username Post: My Ailing High School Sweetheart - 92 Sub
07-10-12 09:45 AM - Post#2246557
    In response to sxerob
The rectangular plastic item hanging off that bracket is your MAP sensor, which tells the computer what the vacuum reading in the engine is. Unrelated completely to what's going on.
Don't let what the parts guy told you confuse the issue. It may be fact that the ESC module isn't available as a new part from O'Reilly's but again that isn't what your code 43 is about. The ESC module is not the knock sensor.
Knock sensors are readily available at any parts house. But check the connection & wiring first. It's possible you bumped the connector off when doing the starter as it's very easy to hit the sensor.
Execution time: 0.119 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:34 PM
