Username Post: Engine questions
Mike_51_Deluxe
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 06:00 AM - Post#2241824
So took her for the first drive in quite awhile. Definitely running better after I made sure the timing was correct. Two issues Id like to get your input on.
First, the valves ticking. I removed the cover and tried to locate the ticking valve/s. While doing this I noticed that the push rods (I think thats what they are) were spinning as they moved up and down, and 2 or 3 were not. Is this normal?
Second, I think something is up with my #3 Cylinder. While running, if I remove the spark plugs there is a noticable change in idle on all plugs but the #3. Its sparking well, and I tested the compression and its 100psi. I then checked the 2nd Cylinder and it was the same, so that ruled that out. Perhaps the valves on cylinder 3 are so out of adjustment that its unable to perform? Thoughts?
Thanks everyone!
Life's too short, do what makes ya happy and transcend the bull$$$hit
Edited by Mike_51_Deluxe on 06-27-12 06:02 AM. Reason for edit: No reason given.
Execution time: 0.061 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:13 AM
