Username Post: service engine soon light
sgian
sgian
Loc: MO
Reg: 12-25-03
06-24-12 03:54 AM - Post#2240670
    In response to evot123
That code could be from something as simple as not putting the gas cap on tight enough or to having to replace the gas cap. Or it can be something more serious. So make sure the gas cap is on tight, and if it is then replace the gas cap. If the light doesn't go away, you could visually check the fuel lines for leaks or damage, or you might need to take it in for diagnostics.
Usually when I get a code, I do a google search for that code number with the terms "OBD II" and I look for sites that give not only the code explanation but also diagnostics. The code number is important to write down or remember after getting it read.
04 Silverado Z71, 10 Cobalt
Execution time: 0.063 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:36 AM
