Username Post: 33 Chevy Water Pump
buggymangp
Reg: 08-26-08
06-19-12 11:58 AM - Post#2239151
    In response to WagonMan
you can also try the filling station.
if you cant tighten down the nut around the shaft to stop the leak most likely the shaft is worn were the packing would ride and no amount of packing will stop the leak. the filling station also sells rebuilding kits for pumps with a new impeller
Execution time: 0.093 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:41 PM
