Username Post: 33 Chevy Water Pump
nellis003
nellis003
Loc: Brookfield, IL
Reg: 09-27-07
06-19-12 10:33 AM - Post#2239133
Hi all,
The water pump on my '33 Chevy seems to be leaking pretty badly. As best as I can tell, it's coming from around the pump shaft rather than the pump-to-block gasket.
It looks like the pump is similar to the Model As where it has a nut you can loosen and then you insert packing material (lead or teflon) around the shaft. But I can't seem to find any source for the packing material.
Can anyone tell me if (a) it does actually work this way, and if so (b) where I can find a packing kit?
Thanks,
Nick
Nick
Brookfield, IL
1950 3100 Hot Rod
1953 3100 Late 235
Execution time: 0.053 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:53 AM
