Username Post: muncie m20 tranny question
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-17-12 05:48 PM - Post#2238416
    In response to 6-bangertim
  • 6-bangertim Said:
The HURST tri-five shifter is universal for ALL the 4-speeds - T-10, Muncie and Saginaw. What IS different is the "Installation Kit" with the shift rods and mounting hardware, sold seperately. I'd say that my shifter sits pretty close to center on the hump in my '57, with a Saginaw-3.11.
The Hurst is a PITA to install, as the stick doesn't unbolt from the shifter body. The stick comes forward 2-1/2 - 3" to clear the bench seat, then curves upward and back. I just kinda guessed where I needed to start cutting the floorboard with a tape measure and a paint stick. I never thought until now to make a cardboard template of the shifter AND STICK to make it less of a guesstimate. Once I got the shifter in the car, it was just a matter trimming the hole big enough to clear the stick for reverse and the forward gears.
To do it again, I would make a cardboard cut-out of the shifter and stick - at least you can bend it around under the car! Well worth the effort for the fun of shifting a HURST on a 4-speed!!!
Good Luck, Tim
My shifter tower is a Hurst, but originally from a MOPAR Pistol Grip in a Challenger. I gave the shift lever to a MOPAR friend, drilled it for the bolt on style holes, as it was a push-in style originally, traded for the right shifter rods and arms, and then bought a Hurst P/N 238-8620 Tri-Five bench seat shift lever. Everything except the new lever were used parts. I can now unbolt the shifter lever from the tower and pull the trans with the shifter tower/linkage intact. All I really have in the setup is what the new shifter lever cost ($$$). I just could'nt see having to remove the shifter tower to remove the trans. Butch/56sedandelivery.
Execution time: 0.101 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:14 PM
