Username Post: Harmonic balancer.
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
06-17-12 05:34 AM - Post#2238145
    In response to csc
I am no historian on this stuff but I think some 327’s were not drilled and tapped for a center bolt. The balancer was a press fit and no bolt was used. Use a mirror and a flashlight and verify you see the fractured end of the bolt before you get too excited.
If it is broken you should be able to use an ex-out to remove it.
To each problem exists a solution...now think.
The ZD Nova Page
Execution time: 0.085 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 AM
