busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
06-16-12 11:28 PM - Post#2238108
In response to MikeB
I do agree I did some more calculations, with your heads you would be at the end of your flow numbers if you went any larger than a 650. The 600 would work well, you might have to richen it on the jets a notch or two and on the secondary side with power valve and open the restrictors. But it should work okay.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2005 Yamaha Vstar 1100 midnight custom |
Edited by busterrm on 06-16-12 11:28 PM. Reason for edit: No reason given.
