Username Post: valve question
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
06-16-12 04:03 PM - Post#2237949
    In response to lilrobo
first pull your valve cover. put a piece of card board from top of fender to top of head so oil does not get all over the place start your car if not getting oil in few seconds. next step would be pull the rocker assemble watch what your doing mark the why it comes apart don't mess with the adjuster since you say it's quite when oil get pressur it will not need adjusting when you put back on. sock in gas or othere cleaner over night disasemble and clean. if you still have samr problem. run a copper tube from oil sending unit by the clutch bar around back of motor to the bolt just above plugs ans 1/2 inch below valve cover died center of head. you'll have all the oil you want
Edited by arnieg141 on 06-16-12 04:06 PM. Reason for edit: No reason given.
Execution time: 0.116 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:18 PM
