Username Post: TBI 454 ran rough now wont start
navygunner08
navygunner08
Loc: New London, CT
Reg: 02-13-11
06-16-12 04:31 AM - Post#2237730
    In response to PC
You can rule out the Ignition Control Module. If that were bad you would not have fuel and/or spark. If you have one or the other, the ICM is good. Have you inspected your your distributor for anything that looks suspicious and loose wires? Pull the cap and roter and look at the contacts for corotion and inspect the spark plug wires for damage. Also search for possible broken wires, connectors and anything electrical that is damaged.
1994 K1500 Z-71
Execution time: 0.109 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:27 PM
