Username Post: Leading a rusted area
2blu52
Reg: 03-12-02
06-11-12 08:08 AM - Post#2235754
    In response to dsacton
Leading was the method used to smooth out low spots in body work prior to the uses of chemical products. If I understand your question correctly you want to lead over areas that are rusted out and this will not work. You need to have back up material and use the lead to finish and smooth up the area. Lead alone will not do the job any more than using bondo over a large hole.
THOMAS JEFFERSON
Execution time: 0.08 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:23 AM
