Username Post: Dynamic CR and Cranking Pressures
BigChevyLover
Reg: 01-20-10
06-08-12 01:18 PM - Post#2234819
Three quick question (before ordering pistons) ...
1. Is a DCR between 7.8-8.0 too high for pump gas with aluminum heads? What would be an ideal DCR?
2. Is a "calculated" cranking pressure of 195 too high for a street car with aluminum heads? What would be an ideal Cranking pressure?
3. Do I subtract 14.7 from the calculated cranking compression to get an idea of what my "actual" compression ratio will be?
For example: I have an online calculator showing a cranking pressure of 195. Is this an an actual cranking pressure of 180.3 psi?
Edited by BigChevyLover on 06-08-12 01:40 PM. Reason for edit: No reason given.
Execution time: 0.086 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:39 PM
