Username Post: Dutch Chevrolet K20 Suburban Silverado 1986
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-07-12 09:12 AM - Post#2234352
    In response to kikkegek
I notice that you are using the standard oil filter. On my Sub I use the heav-duty 2 quart filter (mine is 2wd). It will stick below your oil pan, but it will be way above your axle. It is almost twice as tall as your present filter.
The Fram # is PH373 (just remember that 373 is the perfect axle ratio). You may be able to cross-over the filter number to something in your area. The last filter that I'd ever use is a Fram. The STP filter has the same number on it. I don't remember who makes the STP filter, but they are a reputable brand.
Edited by Stinky on 06-07-12 09:13 AM. Reason for edit: No reason given.
Execution time: 0.101 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:02 AM
