tarps (7)
Username Post: ZZ-2 Heads
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
05-29-12 11:30 AM - Post#2231160
    In response to C10 Sleeper
IMO, I would hold off until you build your 383--why pay to do things twice? Now if you plan on selling your 355 and purchasing or building a 383, then that is one thing, but if you are planning on turning your 355 into a 383, hold off. You will want to change a lot.
Your present cam is a good choice for a 355, and if you upgrade to a better flowing set of heads, choose a head in the 180-190 cfm range with a combustion chamber around 64cc's. 200 is too big--better for a 383 than a 355. Depending on how much you want to spend, AFR, Profiler, Brodix, and RHS aluminum heads are very good choices.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, Sanderson. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
Execution time: 0.086 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:54 PM
