Username Post: Vacuum for AC/heat controls?
kangaroo
Reg: 11-04-06
05-26-12 12:56 PM - Post#2230058
84 c-10
I have hooked a vacuum tester to the system from the engine compartment and do not get a solid reading. I can pump the system to 15 hg but it slowly goes down to about 3-4 pounds. Is this normal? I am thinking that it should hold vacuum and not slowly "leak"? I checked my 89 with the same system and it does pretty much the same.
Execution time: 0.052 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:55 AM
