Username Post: tank switch valve ???
m00n1957
Reg: 03-25-04
05-14-12 08:10 AM - Post#2225765
i thought there might be a problem with switching tanks but i've ran it enough to see that it's pulling fuel from both tanks and is registering from proper tank. obviously the small line is the return since it's pumping gas back to the tank, i plugged that line and left the 2 that return to tanks open since there was no fuel coming from them nor have i had any fuel leakage anywhere. i used he 3 port because i already had it and saw it could be hooked up. i may have a problem with the open lines when i top off tanks so i'm gonna go ahead and get a 6 port switch.
Execution time: 0.088 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:17 AM
