Username Post: Rear main seal on motor. 78 big10 327
csc
Reg: 12-05-10
05-07-12 11:24 AM - Post#2223443
    In response to csc
Or is that ok? oil shouldnt get that far should it? The top part of gasget came out with out loosening anything other the rear clamp(not sure what its called). The filler has some minor scratches but nothing that looks to be discolored. With the clamp having that crack, will oil pan seal properly? should i change filler to be safe? Where is best place to get that part?
Again thanx so much.
Edited by csc on 05-07-12 11:48 AM. Reason for edit: No reason given.
Execution time: 0.07 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:15 AM
