Username Post: 98 silverado misfire
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
05-06-12 09:55 AM - Post#2223094
    In response to chevyracing58
Its no more difficult on the vortec then any other SBC, basically the same. It could be other things but if you can rule this common fault by checking for vacuum. If you have vacuum in the crank case then it is the gasket. The problem with the vortec is that they used a plastic gasket with rubber o ring and the plastic melts/warps over time.
98 Silverado k1500 4x4 350
Execution time: 0.075 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:09 AM
