Username Post: Left rear light assembly inop
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-02-12 06:46 PM - Post#2221731
    In response to catalano82
I know you checked the grounds, but real quickly: Did you remove the ground screw and buff the rings, the screw head and the spot on the frame around the hole and then tighten everything up again? The grounding system does require a little maintenance on occasion even when the straps are still intact.
Greg
'94 Silverado K2500 4X4 5.7 5spd Xcab LB
RV cam, Pace Setter Headers, TBI spacer, Flow Tech air cleaner adapter, Hypertech street chip
Execution time: 0.075 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:58 AM
