Username Post: 350 SB Gear Drive Headache
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
04-24-12 02:06 PM - Post#2218715
    In response to D.Mac
  • D.Mac Said:
That cam should go farther into the block than that. Make sure it is not hitting the cam bore plug in the back of the block.
Bingo! Nose of cam should be just about flush with front of block. Your rear plug is tapped in too far, or there's a problem with one of the cam journals or bearings.
Is this a roller cam? If not, you don't need a thrust button.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Execution time: 0.066 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:04 AM
