Username Post: Code 32 bad idle/fuel mileage
timcrunch
Loc: Kentucky
Reg: 04-17-12
04-21-12 11:54 PM - Post#2217760
    In response to someotherguy
New temp sensor, no I think its running a 165 thermostat. The old 195 was bad and only replacement they had in stock that day was 165, guy said it would be fine, but when your stuck on the side of the road you do what you have to.
Anyhow do you think that could be causing the code 45? I thought the IAC would be the problem since the truck is idling all over the place (from 400-1000 rpm).
Execution time: 0.227 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:43 PM
