Username Post: engine popping sound
tri5ss
tri5ss
Loc: Massachusetts
Reg: 12-14-00
04-19-12 11:58 AM - Post#2216934
    In response to FlyinRed7
How about something as simple as a broken/cracked distributor cap or a bad/worn rotor. My old motor did the same thing a couple of days before it actually quit. Fix, new cap and rotor. See if you have any "black" spots on the inside of the cap and look for wear marks on the rotor. You may get lucky and find it's a quick and relatively inexpensive fix.
Good luck,
Randy
Tri5SS
'55 210, GMPP ZZZ, 200 4R, 12 bolt 3.73 posi, CPP P/S, ABS D/B.
http://www.picturetrail.com/tri5ss
Nothing is foolproof to a sufficently talented fool!
Execution time: 0.106 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:28 AM
