Username Post: Okie bushing
Loc: Ellijay, GA
04-17-12 11:19 AM - Post#2216166
    In response to fiftone
  • fiftone Said:
For something that is suppose to be a quick fix, it sure turned out to be a pain in the rear. I told the mechanic to put the 4 shims in and torque to 4 bolts to 12 ft lbs. As 2blue2 stated above, I hope it just wears in. I will check the torque on the bolts every so often just in case it does wear in and the bolts loosen up a bit.
It is a fix, but would not call it a quick fix.
Execution time: 0.083 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:25 AM
