tarps (7)
Username Post: Rhoads Lifters???
models916
Loc: Addison, IL
Reg: 05-28-10
03-26-12 07:17 AM - Post#2207610
    In response to ALS57
I use them in everything. Slight ticking sound at idle. Allows you to run a larger cam than you should. The ticking is the valve dropping back onto the seat as the lifter fast bleeds. Kind of sounds like a solid cam but much quieter. There are those that don't like the sound. My 409 should have a solid cam anyhow, so this is just a little quieter. There are a couple different versions of them out there now, mine are the original fast bleed Hyd.
Execution time: 0.109 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 PM
