of this great
online community.
N8sToolz
Loc: N 42° 53.290' W71° 34.1...
Reg: 10-23-03
02-22-12 08:25 PM - Post#2194054
In response to stumppuller
In the 80's Only the 305 and 4.3 had the ESC system. It is possible that is the case even with the newer trucks.
Also, if the knock sensor was disconnected and a fault was detected, it would revert to a 'safe' timing curve, or fixed timing. I doubt thats what caused the overheating.
The water pump type used is dependent on if its turned by a v-belt or serpentine belt. serpentine belt would spin opposite the engine rotation while a v-belt would spin the same direction.
1982 Chevy K20 Converted from C20.
355/700R4
2002 Yamaha XVS1100CL VStar
2002 S10 2WD |
