Join the Community today
Username Post: Complete rebuild of steering box/column
nashvegas99
nashvegas99
Loc: Pegram, TN
Reg: 08-13-08
09-08-09 10:08 AM - Post#1768218
thank you. I am going to attempt it with the pitman arm in removed from the shaft. If I am lucky enough for this to happen, when I remove the flat sector plate, should I be able to remove the roller mech? Which way should I try to push the bearing and retainer out?
http://www.picturetrail.com/sfx/album/view/225743 4...
Execution time: 0.213 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:59 AM
