Username Post: Electric Cutoff Switch
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
01-01-18 11:43 AM - Post#2719685
    In response to Jim Streib
Well Jim, regarding ‘shorting out’, I see nothing around the cold side of the solenoid post but the battery cable securely fastened to it and lots of empty space. As far as exposure for it to short, I see no difference in that and the cable being attached to the battery post to start with. Internally inside the solenoid, it’s either latched and current going through or unlatched and open. Only thing internally to short with would be the two toggle switch terminals and their both fused @ 5 amps. Feel like if it were a potential problem area, the tech boys at Hotronics after all these years, would have been on it a long time ago. However, appreciate your insight and comments on the subject.
50s Chevys
Execution time: 0.181 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:53 AM
