Username Post: Wont start
Chevytech
Chevytech
Reg: 04-25-04
01-01-18 09:36 AM - Post#2719665
    In response to Jeffrey0180
On a 1994 TBI the timing is set with a timing light. It is newer trucks that are set with a scan tool.
To set the timing you will need to unplug the set timing wire and on a 1994 it is in the cab by the computer.
Set timing wire photos:
Set the timing to zero degrees BTDC if it is a small block.
Execution time: 0.171 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:24 AM
