Username Post: Timing issues
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-01-18 06:57 AM - Post#2719631
you can,t fix a damn thing until you have verified facts and know what your dealing with
start by verifying tdc on the damper and timing tab reflect reality then map the timing curve
reading links may not be fun but it beats not having the car run decent by a long way
Execution time: 0.288 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:30 PM
