Username Post: Heater Plumbing
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
11-30-17 04:47 AM - Post#2716357
    In response to Rustchips
Hmmmmmm my water connections on my heater are side by side. The instructions that came with valve says on engine side says "outlet to water pump" and "inlet from Intake Manifold". I am assuming this is for a V8. So, just to make it clear to me, I am assuming "the inlet from Intake Manifold" will connect to thermostat housing. Correct?
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
Execution time: 0.518 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:33 AM
