Username Post: How much PAG oil to dry a/c system?
dually502
Reg: 09-13-09
08-08-12 06:06 AM - Post#2257028
    In response to someotherguy
Found this in All DATA
Refrigerant Oil Distribution
Notes
REFRIGERANT OIL DISTRIBUTION
The Harrison HT-6 compressor system used on all models requires polyalkaline glycol (PAG) refrigerant oil in the quantities listed below:
Without Aux. A/C - 240 ml (8 fl oz)
With Aux. A/C - 330 ml (11 fl oz)
New oil quantities must be added to the system during component replacement and conditions stated as follows:
With no signs of excessive oil leakage, add:
All Compressors (drain and measure the oil)
If less than 30 ml (1 fl oz) is drained-add 60 ml (2 fl oz) to the new compressor.
If more than 30 ml (1 fl oz) is drained-add same amount that was drained to the new compressor.
Accumulator-Add 105 ml (3.5 fl oz) of new oil to the replacement accumulator to compensate for oil retained by original accumulator desiccant and bag assemblies. The accumulator should only be replaced if leaking due to a perforation, damaged O-ring seal seat, or damaged threads.
Evaporator-Add 90 ml (3 fl oz) of new refrigerant oil.
Condenser-Add 30 ml (1 fl oz) of new refrigerant oil.
Yeah, I am glad I flushed it out.. About to install the dryer and go get it charged up..
Execution time: 0.073 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:06 AM
