Username Post: JAMCO PBB 4954 Power Brake Booster
Chevy Tin Man
Chevy Tin Man
Loc: Plant City, (Tampa) FL
Reg: 02-07-12
08-04-12 06:07 PM - Post#2255766
    In response to mahlmann
MIKE, another thing you will have to do is turn the brake pedal pad mount 180 degrees. If it's like mine it put it to close to the accellerator. I had to do all new lines, move the exhaust pipe over. It was a bunch of work but good in the end.
GOOD LUCK, STEVE
You will need residual valves too.
YOU TELLM 'HELLS A COMIN" I'm bringin it with me.
Edited by Chevy Tin Man on 08-04-12 06:09 PM. Reason for edit: No reason given.
Execution time: 0.067 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:03 AM
