Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
07-24-12 01:51 PM - Post#2251725
In response to Steve P
GM HEI. Is that correct?
No.
You need to select:
Ignition Type - "Custom"
Crank Sensor Type - "1 Pulse/Fire"
Sensor Type - "Digital Falling"
Ignition Reference Angle - 60°
Cam Sensor - "Not Used"
Output Setup Type - "Points Output"
Dwell Time - "2.0 msec"
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires |
