Username Post: Oil spray on undercarriage-Should I be concerned?
Gray Headed Mule
Gray Headed Mule
Loc: Fort Worth, Texas
07-10-12 01:46 PM - Post#2246662
    In response to iRiE
It may not be a problem at all. I was having the same problem with mine but it was a v8. you didn't specify what kind of engine it has.
BUT my problem was a bolt in the front of the engine that was missing. It's the bolt that holds the fuel pump rod up when you are changing out the fuel pump. It didn't leak at idle but when reving or driving it would throw oil out of the hole and cover the underneath side like you are talking about.
Mule
I'm sexy and I know it!
My 49 Chevy Fleetline Deluxe Restoration Project
Execution time: 0.088 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 AM
