06-24-12 05:24 PM - Post#2240905
In response to Henrys57wagon
I agree with you Henry. You want the temperature sensor in the coolant that's hot and going into the radiator, not the cooled coolant coming out of it.
If your radiator and fan is working right, the temperature of the coolant coming OUT of the radiator is 30-50º LESS than the inlet temperature.
If you don't have a spot to put the extra sensor, get an inexpensive spacer with extra ports that goes under the thermostat housing. Summit and Jeg's have them.
