tarps (7)
Username Post: Harmonic balancer.
66cayne
Reg: 08-06-08
06-17-12 06:09 AM - Post#2238160
    In response to 72novaproject
Yes, what he said.. When you look at the end of the crank you will see it has a machined opening on the end of the snout. You will want to drill and tap it for a balancer retention bolt. Also, if your balancer came off the woodruff key is probably ruined too. Install a new one before putting the balancer back on.
Execution time: 0.275 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:35 AM
