Username Post: engine/trans/driveshaft/pinion angle
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
06-10-12 07:53 AM - Post#2235394
    In response to Rick_L
Does you digital level have a zero reset? I'm thinkin that if you zero the level while it is position vertically on the rear flange of the transmission and then check the rearend pinion angle, without resetting the level, you would get an actual difference in angle reading. An "0" degree would represent a parallel drivtrain.
Execution time: 0.158 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:37 AM
