Username Post: HEI advance curve?
kangaroo
Reg: 11-04-06
05-16-12 08:22 PM - Post#2226716
    In response to FleetsideLarry
I am looking for info on the dist. as far as the advance curve that it comes with. There no info on the web site or instructions. I did find that if its any thing like a Pontiac its curve is pretty close to what I want.
The centrifugal advance consists of OEM-quality weights and center plate providing 22 to 24 degrees by 3,200 rpm, and an adjustable vacuum advance canister preset to 15 degrees. Available from your nearest Proform distributor or mail-order supplier, Pontiac V-8 HEI (No. 66953) retails for $190.
Read more: http://www.highperformancepontiac.com/tech/hppp_08...
Dont know how accurate this info is but if anyone is looking for the 375 and 41 weights you might want to check here.
If you would like to purchase OEM-type weights and center plates, contact D&D Manufacturing, Inc., Memphis, TN (901) 458-3287 for more information.
Edited by kangaroo on 05-16-12 08:33 PM. Reason for edit: No reason given.
Execution time: 0.088 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:46 AM
