Username Post: Shifter problem?
2-28s313233
2-28s313233
Loc: DFW Texas
Reg: 02-24-05
05-08-12 08:49 AM - Post#2223755
    In response to inkedflesh
As the others have said, the bushings in the linkage need to be in good shape. You can take the shifter box off the steering coulmn and clean it out and check the spring inside to be sure it is not broken. Sometimes it helps to file the cap on the box to provide a better fit on the shifting shafts, if it is worn excessively. And fill it with a light grease.
Cleon
1928 Chevy touring
1942 Chevy Sport coupe
1949 Chevy Sport coupe
1954 Chevy Bel Air HTP
1970 El Camino
1971 Monte Carlo
Execution time: 0.092 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:08 PM
