Username Post: weird washer sprayer issue
drifterdude
Reg: 09-04-08
05-08-12 08:02 AM - Post#2223743
    In response to someotherguy
Ill go back over it but I heated all the joints again and add fresh silver solder to them. Also would it help any to run the ground for the sprayer motor straight to the body? If so I could run it to a mounting bolt for the bottle.
92 K1500:350 bored 30 over,built 700r4,Comp extreme energy cam,double roller timing set,shaved heads,Rancho RS9000XL series shocks with wireless my ride system,35 inch Mickey Thompson Baja Claws,Relocated 4x4 switch to rocker on Dash.
Other mods..
Execution time: 0.127 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:36 PM
