of this great
online community.
drifterdude
Reg: 09-04-08
05-02-12 01:17 PM - Post#2221618
In response to someotherguy
I replaced the clips and lubed it cause I had to reach in by hand and squeeze the levers as the rods would pop out or it would be to stiff to lift the handle.
But if I do pull it a bit on that side it does open up just fine but the movement on driver and passenger side looks equal for how far they pull.
I thought about pulling the assembly again and trying to add metal to the top of the arm so that it pulls a bit futher when you lift the handle. Rig it untill I can find all new parts for it along with a bezel. Im mainly tired of sticking my fat hand up there to open it.
92 K1500:350 bored 30 over,built 700r4,Comp extreme energy cam,double roller timing set,shaved heads,Rancho RS9000XL series shocks with wireless my ride system,35 inch Mickey Thompson Baja Claws,Relocated 4x4 switch to rocker on Dash.
Other mods.. |
