Username Post: Wheel fitment?
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
04-25-12 07:17 AM - Post#2218930
    In response to 53belair
The first link has some rear end dimensions. If the Cutlass is the same as the same year Monte it would be 58". If that is the case, you'd better double check the backspacing. You're going to be a inch closer to the inner fender and springs than with the 60" original. Simple math suggests that you're going to need something closer to a 3" BS rather than the 4".
http://www.carnut.com/specs/rear.html
Just for info. purposes this attached link is for a really cool worksheet that was put together for the tri five to fit wheels, tires, and rear axle assemblies. Ours won't be the same but the data is good to have.
http://tri-5.chevyrides.com/rear_tire.php
Edited by 53belair on 04-25-12 07:26 AM. Reason for edit: No reason given.
Execution time: 0.093 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:17 AM
