1928isgreatnauta (7)
Username Post: 350 SB Gear Drive Headache
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
04-24-12 09:32 AM - Post#2218640
    In response to virtualAnarchy
I agree with D.Mac...The cam should go further back. The motor may have run but the cam is probally riding on the rear cam plug. This is also placing the lifters in a different location than designed on the cam lobes. When you relocate the cam back into the block you will have to reset you timing and also reseat your lifters to the cam. On the cam button issue, different covers require different length buttons. The prefered cover will have a 3 peice pie circle look for the button you have.
Execution time: 0.131 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:57 PM
