tarps (7)
Username Post: 83 turn signal not working
Senior Chevytalk Moderator
03-19-12 04:46 PM - Post#2204738
    In response to Allan In NE
Welcome to the site. Your info is confusing. I assume the turn signal did not work prior to switch replacement. Now after replacing the switch, the flashers work but not the turn signals. Has the steering column been replaced? Check the connections at the base of the column.
'96 GMC Jimmy LS
Execution time: 0.087 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:16 AM
