Username Post: 100 to 150 rpm surge
tvrc18
Reg: 02-28-12
03-11-12 02:01 PM - Post#2201245
    In response to tvrc18
I tried looking for a vacuum leak today and had no luck. I did not have carb cleaner but read you can squirt water and get same results. I sprayed all around the hoses for pvc, cannister purge lines and upper intake manifold and no change in engine sound. I think I will take it to the tranny shop and have the valve body checked and maybe the sonnax kit put in it.
Execution time: 0.086 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:33 AM
