Username Post: outside upper SS trim below rear window -removal
57belairman
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
02-23-12 09:05 PM - Post#2194489
    In response to GaryC
If you remove the door panel and the lower excess cover you will see a rubber window stop in the bottom of the door. if you remove this stop and roll the window all the way down you might be able to remove the screws without removing the window. It's about 1/2 inch thick. Might be just enough.
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible
57 Nomad
57 2dr Sedan
57 3100 Pickup
55 2dr Sedan
56 Suburban
Execution time: 0.081 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:16 AM
